Peytonloki's avatar
Nov 17, 2020
Circle Premium no longer working
As of 11/12 Circle is no longer blocking websites based on settings. The visited and filtered history are also no longer populating. And off times are no longer respected.
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello Peytonloki,
    May you power cycle your router and reinstall the Circle app.
    Thanks,
    Christian
    • Peytonloki's avatar
      Peytonloki
      Tutor
      Thanks for the reply Christian.  I've done both of those things, as well as taken updates on router as well.
        Christian_R
        Hi Peytonloki,
        May you factory reset your router by holding down on the reset button for 15+ seconds using a pin/needle. You will need to run through the setup assistant again and you may do so using the Orbi app.
        Christian
