rich1231
Jan 26, 2018Aspirant
Circle seems to have broken my network
I setup enabled circle earlier after updating my Router. Installed the app, connected app to the router and configured a few devices. Devices with no filters attached which were set to unmanaged, a...
- Jan 26, 2018Hi.
If you still able to get to router interface, flash it back to v.1.0.3.54 for now. And then do hard reset the router. This should help you get stable router function (but no Circle application for this version, only DDNS parental control ). Netgear is debugging firmware and hopefully they will get new update stable firmware soon. When? I do not know for sure.
Terry
TerryPh
Jan 26, 2018Virtuoso
Hi.
Terry
Terry
rich1231
Jan 27, 2018Aspirant
Thanks that did the trick. I had tried to restore a slight younger firmware but the issue remained..
I am assuming that once activated Circle's ARP Spoofing stays in place even after disabling on the router. Which is really terrible.
