rich1231
Jan 26, 2018Aspirant
Circle seems to have broken my network
I setup enabled circle earlier after updating my Router. Installed the app, connected app to the router and configured a few devices. Devices with no filters attached which were set to unmanaged, a...
- Jan 26, 2018Hi.
If you still able to get to router interface, flash it back to v.1.0.3.54 for now. And then do hard reset the router. This should help you get stable router function (but no Circle application for this version, only DDNS parental control ). Netgear is debugging firmware and hopefully they will get new update stable firmware soon. When? I do not know for sure.
Terry
TerryPh
Jan 26, 2018Virtuoso
Hi.
Terry
Terry
SarveshMurthi
Feb 20, 2018Aspirant
I rollback the Firmware Version V1.0.3.54_1.1.37 and monitored for 1hr still same unidentified device appearing in random.
I monitored for 3hr at random and found more than ten unidentified device appearing in random and I captured some of the devices hose list is below.
SL | Manufacturer | Model | Model Number | MAC address |
1 | INTEX | Aqua Power+ | Aqua Power+ | 3C.97.0F.53.E6.15 |
2 | LENOVO | TAB 2 A10-70L | TAB 2 A10-70L | 98.0C.A5.C8.5E.DF |
3 | LENOVO | A7010a48 | A7010a48 | 98.0C.A5.B9.D3.9F |
4 | COOLPAD | CP8298_I00 | CP8298_I00 | D0.37.42.C3.C2.51 |
5 | IBALL | D7061 | D7061 | 40.20.00.28.42.30 |
6 | PANASONIC | P55 Novo | P55 Novo | 70.0B.C0.92.96.A2 |
7 | TCL | 6042D | 6042D | D8.E5.6D.CB.36.4F |
8 | LAVA | A3_mini | A3_mini | 48.FC.B6.73.66.C0 |
9 | VIVO | 1609 | 1609 | BC.2F.3D.2E.7E.4A |
10 | HTC | Desire 728 Dual Sim | Desire 728 Dual Sim | 04.E2.3E.3F.04.0F |
11 | ASUS | ASUS_T00J | ASUS_T00J | 08.62.66.07.02.D0 |
12 | MOTOROLA | XT1663 | XT1663 | 48.88.CA.24.42.FE |
