1sharpfamily
Jan 05, 2018Follower
Enable for Circle with Disney missing on R7000P
I had previously updated the firmware shortly after original installation before attempting to setup Circle with Disney. Following the instructions in the manual page 39-40, for "Enable Circle With Disney On Your Router" I am unable to update my firmware since it is up to date. So "The enable Circle with Disney page displays after the firmware is updated." in step 5 does not appear. So I do not see an option to enable Circle anywhere now. This is one of the reasons I purchased this router. Please help me so I can enable Circle with Disney.
Hi 1sharpfamily,
On the router UI, you can go to Basic > Parental Controls > toggle Circle with Disney. Or you may use the Circle App using the steps linked below.
https://kb.netgear.com/000038870/
Dexter
Community Team
- DexterJBNETGEAR Moderator
Hi 1sharpfamily,
Dexter
Community Team
Hi 1sharpfamily,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
