juched
Dec 08, 2017Apprentice
R7000 - Disney Circle - Internet speeds through router slowdown
Creating a new thread to focus on this one issue. I don't believe this is a general slow wifi/slow internet issue, but is clearly Circle related. All tests done on wired connection via my Net...
Michaeldx
Oct 05, 2018Aspirant
Having the same issue. When I have Circle enabled, it cuts my speeds in half. Disabled, I get full speed. With OpenDNS I get full speeds, so I'm going back to using that.
I did NOT have IPV6 enabled at all.
TomBT
Oct 05, 2018Guide
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Neato-Robot-and-R7000/m-p/1615905/highlight/true#M100992
Try my suggestions in this thread. After a firmware update and resetting the machine a few times, mine is working now. It may have had something to do with my switch to tomato and back again.
- Kyle_PHXOct 05, 2018GuideSame problem here, didn't notice so bad until recently, but with the latest firmware update, page loads from my phone (Android Oreo on HTC U11) are brutally slow, and similar slowness on other devices too, with 80Mbps service. Will try a reset I guess and see if it makes any difference. I really like the Circle functionality for limiting my kids' access, but it's looking my connection does. IPv6 disabled here too.
- runboyNov 03, 2018Initiate
330Mbps without Circle enabled and 150Mbps with Circle enabled.
Hope they figure this out since I do like how easy Circle is to configure.
- etchaNov 06, 2018Aspirant
Same issue. Cancelled circle subscription today. 330 with circle disabled, 120 with circle enabled. Cant justify turning it back on with over half the bandwidth lost. Will just have to turn devices on and off manually using the nighthawk phone app.
