juched
Dec 08, 2017Apprentice
R7000 - Disney Circle - Internet speeds through router slowdown
Creating a new thread to focus on this one issue. I don't believe this is a general slow wifi/slow internet issue, but is clearly Circle related. All tests done on wired connection via my Net...
KnightSi99
Dec 05, 2018Tutor
Hi there, same issue here. I'm not sure if it was this thread or a different one, but someone had recommended resetting the device back to factory defaults after doing a firmware update each time and enabling Circle again. Although I feel we shouldn't have to do that, I really do like Circle so I figured I give it a go. So when I updated to FW V1.0.9.42_10.2.44, I did exactly that. I reset the router back to factory defaults and changed settings back to the way I had them, like setting DNS to use OpenDNS, enabling Smart Connect for my wifi, etc. So after doing all that, my download and upload speeds have been consistent to what my isp advertises now. I figured on the next FW update, I'll try updating without having to reset factory defaults and see how that goes. Anyway, just wanted to share my experience.
Thorz
Dec 05, 2018Star
I also like Circle and what it offers. What are your internet speeds with and without Circle activated?
Reseting the router to factory defaults and configuring everything manually again is a PITA. I have multiple IP reservations in the DHCP scope, static DNS, multiple static port forwards, this is going to take an eternity to configure again, and if this indeed work as you are posting and this has to be done after every single firmware update the cost of mantaining this solution in time is going to be really high.
Does anyone know of another product that offers time control similar to what Circle does and that doesn't involve the level of frustration Circle on Netgear devices has?
