AmniClave
Sep 22, 2025Aspirant
This is a known issue with Circle’s certificate on the CBR750
This is a known issue with Circle’s certificate on the CBR750. The “20-year validity” makes browsers/devices flag it as untrusted. The quick workaround is what you’ve already done (toggle parental controls), but the real fix will need a firmware update with a new certificate from Circle/Netgear. Best step: open a support ticket with Netgear so they can escalate to Circle Labs — they’ll need to push an updated, trusted cert in the next firmware.
1 Reply
FYI, Circle feature has been discontinued.
https://kb.netgear.com/000063022/Support-for-Live-Parental-Controls-ends-April-1-2021
NG has moved to using Smart Parental Control feature for NG routers.
https://kb.netgear.com/000063635/How-do-I-get-help-with-my-NETGEAR-subscription-service
