nzsatish
Sep 11, 2022Follower
Unable to connect circle app with Nighthawk R7960P Router
I am using the Nighthawk R7960P router with the Circle app. I have been using the circle app for over two years, and I turned off the internet for my son's laptop. Now the circle app is not able t...
Sep 12, 2022Guru - Experienced User
What NH app version are you using?
Apple or Android?
Have you powered OFF the ISP modem, router and your mobile phone for 1 minute then back ON and see if the NH Circle app can connect to the router?
