CherryMI's avatar
Nov 29, 2022
Anywhere Access
I was told by Netgear support that there is an ongoing problem currently using Anywhere Access from my Mobile Device.  Does anyone know if there is a timeframe to resolve.  When I try to access my router remotely, I continue to get the message that the router cannot be found.  I've had the problem before and for some reason it has resolved itself within a day.  This time, it has been unreachable for 5 days and still not able to connect.
  • FURRYe38's avatar
    Yes and no, NG doesn't post when this will be fixed.
    What mobile platform are you using?
    Can you connect while at home on local network?
    What NG model router do you have?
    • CherryMI's avatar
      CherryMI
      Tutor
      I can connect while connected to the local network and I am on an Apple IOS.  I have seen this happened every now and then but it always resolves itself.  The router is a Nighthawk R7000P.
      Since I am away from home at the moment, I had a friend go cycle the router and this did not resolve the issue.
  • michaelkenward's avatar
    michaelkenward
    You don't say what Netgear support said, what your mobile device is or when you talked to them.
    There was a problem with the Android version of the app and Anywhere Access.
    They fixed it about a week ago.
    Unfortunately, not for the first time, fixing Android broke iOS.
    It took about a month to mend the Android app. It is anybody's guess as to how long they will take to fix iOS.
