AEJsMom's avatar
AEJsMom
Follower
Oct 02, 2017
Attached Devices / Network Map
My Samsung TV does not show up in the Network Map in Netgear Genie nor Attached Devices when I login on routerlogin.com. The TV is currently connected to the internet and streaming YouTube.
  • Hi AEJsMom,
    1. What is the firmware version of the device?
    2. Is the TV connected via WiFi? If yes, please try hardwiring the TV to the device and check if the issue persists.
    3. Please make sure the TV is connected to the correct SSID/WiFi.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi AEJsMom,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi AEJsMom,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
