schumaku
Apr 15, 2019Guru - Experienced User
BUG REPORT: Speed Test Information Home Screen Wrong, Speed Test on Router QoS, Localisation, (c)...
Nightawk App, v2.3.1.568 Google Pixel 2, Andoroid 9, up2date
Management Summary: Careless design, poor programming, lack of QA.
Issue A: On the Nighthawk App "Home" view, the (new added)...
ChristineT
Apr 25, 2019NETGEAR Employee Retired
Good Afternoon schumaku ,
Thank you for this extremely detailed report! I have provided your feedback to our support and products teams for review.
Best Regards,
Christine
schumaku
Apr 25, 2019Guru - Experienced User
Thank you ChristineT - convinced there is more to come, os here we go:
Issue Q: Nighthawk App (typically iOS) does not show the On/Off controls to enable/disable devices (typically R8000 and/or R8000P router).
- schumakuApr 25, 2019Guru - Experienced User
Issue R: No Bypass Login Capability for Live Parental Controls
Using desktop Genie only addresses setting the parental control on the local network - the bypass login capability allows the parental level to be controlled when the portable device is remote on a different network or a mobile phone connection. Very frustrating that this cannot be done any more.
- schumakuApr 28, 2019Guru - Experienced User
Issue T: ReadySHARE access feature with simple up- and download on a tabbed side-by-side Local and ReadySHARE Lost on the Nighthawk App
Thank you Drew-Z for the additional issue - must have missed that one. Do I qualify as a product manager with Netgear now, too 8-) ?
Drew-Z wrote:
I updated the firmware in my R7000/AC1900 router and the genie app lost its ability to communicate with my router. And now I have lost the ability to access my readyshare USB drive hooked to my router via my Android phone. The Nighthawk app doesn't have the feature for readyshare drive access.
Wow Netgear, yet another thing destroyed! While the most obvious idea would be to promote the ReadyCLOUD App, the simple up- and download capability with the side-by-side folders (in two tabs) for local and remote is not available. Christian_R more qualified complaints here (ref. both the Nighthawk App as well as for the ReadyCLOUD App!).
- schumakuApr 30, 2019Guru - Experienced User
Issue U: Netgear does fail again to make things clear. Why on earth don't they use the term "Circle" or "Circle by Disney" also on the App? No, they replace it (apparently) by a tile named "Parental Control" and confuse both the Live Parental Control (OpenDNS based) as in place on many Netgear routers.
- schumakuMay 16, 2019Guru - Experienced User
Issue V: Devices view does list in grups for 5 GHz, 2.4 GHz, and Wired. All groups have an (i) - when using the (i) on the Wired , we get this "Understanding WiFi" message - complete unrelated to weired network devices:
- schumakuMay 21, 2019Guru - Experienced User
Issue X: Issues with multiple Wireless Extenders - Mixing and Duplicating Information
DUT: R8000 - SherryJC thank you for the report!
FMI: https://community.netgear.com/t5/Nighthawk-App/Nighthawk-app-duplicating-information/m-p/1754322#M9551 - schumakuMay 21, 2019Guru - Experienced User
Issue Y: No Devices listed with Nightawk Gaming Pro
FMI: https://community.netgear.com/t5/Nighthawk-App/XR500-Nighthawk-iOS-app-no-devices-listed/m-p/1730765#M9295
Thank you AdrianLab for the report - sorry for being late replicating it to this list....Christian_R we have almost reached A..Z and ZERO feedback from the Netgear CHP g*****e departmement. Instead, we find the community flooded with marketing stuff nobody want to see here. We need fixes and solutions - in time.
- schumakuMay 27, 2019Guru - Experienced User
Issue Z: The Nighthawk App does refuse to connect to a supported Nighthawk device if it's operating in Access Point mode.
We're through the alphabet now. And Netgear does hide. It's just ridiculous. Christian_R
- schumakuJun 01, 2019Guru - Experienced User
Issue AA: While Remote Management, changing Wireless Mode (e.g. Smart Connect Off, Smart Connect on), we're sent to a waiting loop for some 70+ seconds, "Searching for Router".
What might make some sense on the local router WLAN, with the remote access there is no reason for this delay and wait - as the connectivity goes over the Internet, and not the local Wireless connection.
Christian_R can we get updates for all the issues posted here please?
- schumakuJun 12, 2019Guru - Experienced User
Issue AB: Nighthawk cannot show wired connected device (R6400)
R6400 firmware: 1.0.1.46
Nighthawk version 2.3.6.617
In my fomer app , Nergear Genie allows me to reach the wired + connected device, such as my television. I can disable the connectivity between that tv and the router.
In the forced update to nighthawk , it does only show wifi connected device.
