Blunty
May 06, 2017Aspirant
Cant login to openDNS from genie
My router is a DGN2200 A few problems - how do I know what version I have as it does not seem to say anywhere - does that mean that this version will not work with Genie? I managed to use the Ge...
Blunty
May 23, 2017Aspirant
Thanks for this - but I am not sure how I don't block everyone - how do I set my computer to have access. Also do you know if the Genie App works on a mac as it sure does not work on my phone, it willnot let me login. It worked the very first time and I was really impressed but would love to get that happening again.
DexterJB
May 30, 2017NETGEAR Moderator
Hi Blunty,
The links below may help out.
http://kb.netgear.com/app/answers/detail/a_id/25687
http://kb.netgear.com/app/answers/detail/a_id/29913
Dexter
Community Team
- DexterJBJun 08, 2017NETGEAR Moderator
Hi Blunty,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- BluntyJun 08, 2017Aspirant
Yes and no - as the screen I can see is this one nad it is pretty limited - I would like to make the genie app work from my computer and my phone as I can't figure out how to only block my kids through this parent control one - it seems complicated
Hi Blunty,
You may want to look into the per device filtering feature of the Genie app. Check the link below for the steps.
Dexter
Community Team
