Spiffy2Man
Oct 11, 2017Aspirant
Circle safe search not working
When I first setup circle on my tablet safe search was working well. After I added all my devices and changed so of the other configuration options I tested everything again. Now safe search doesn't w...
DexterJB
Oct 17, 2017NETGEAR Moderator
Hi Spiffy2Man,
1. What is the firmware version of the R7000?
2. What is the operating system (Android or iOS) of the device that you used to configure the Circle settings?
3. Does the issue (wrong filtering) persist on all your devices?
4. Have you tried resetting the router?
Dexter
Community Team
DexterJB
Oct 24, 2017NETGEAR Moderator
Hi Spiffy2Man,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- Spiffy2ManDec 31, 2017Aspirant
