doug0312's avatar
Mar 03, 2021
Circle won't configure on new R7000P
I just purchased a Nighthawk R700P router specifically to use the Circle features to manage kids devices.  does this even work?  it seems like it's DOA out of the box.
The Circle wil not configure.  Have tried:
1. Restoring Router to Factory (twice)
2. Uninstalling/reinstalling Nighthawk app on iOS
3. Uninstalling/reinstalling Circle 1 app on iOS
I have Enabled Parental Controls, and then Circle via a browser to the router's config page.
on iOS, this is what's happening:
a. connect iOS Wifi to the router's SSID
b. Launch Nighthawk app
c. Click on "Parental Controls" widget.  This brings me to a 'Circle 1st gen' page with a Get Started Button, and a second button to "Set up Circle on supported NETGEAR routers".  I click the second button.
d. This brings me to "Circle on Netgear / Circle on your router!".  I click NEXT
e. This displays error page "Darn, couldn't find Circle on your router"
I've looped on this over a dozen times.  Reboot router.  Reset router to factory.
  • michaelkenward's avatar
    michaelkenward
    What firmware version do you have on the device? You need the right version to get Circle to work.
    A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
    It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
    The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
    As your issue seems to be with the R7000P and Circle, the section for the Nighthawk App might not be the best place to get help.
    Have you tried this issue in the section given over to Circle?
    Circle Smart Parental Controls - NETGEAR Communities
    Then there is the section for the R7000P:
    Nighthawk WiFi Routers
    • doug0312's avatar
      doug0312
      Guide
      Thank you.  I will repost in both those forums.
      In answer to your question, the 7000P Firmware number is V1.3.1.64_10.1.36
      This is plugged directly into the standard Comcast modem.  I've cheked that there are no IP conflicts with the Comcast modem, it is 10.0.0.1 and a DHCP server starting on that subnet.  I have the Nighthawk 7000P configured as 100.0.0.1 and a DHCP server on THAT subnet.
      Off the Nighthawk, while Debugging, I have only 1 Ethernet computer (an iMac Pro running Big Sur) and one device connected by Wifi (an iPhone running iOS 14.4)
      This is the most vanilla setup I could arrange.  The router seems to work fine for traffic, but the Circle feature appears to be Dead on Arrival.
        michaelkenward
        Unfortunately, "standard Comcast modem" tells us nothing about what this device is.
        I have yet to encounter a modem or modem/router that does not have a make and model number. Only with that detail can anyone begin to troubleshoot your problem.
        Talk of "IP conflicts" is a red herring.
        None of the rest makes sense. If your Comcast modem is on 10.0.0.1, it probably isn't a plain vanilla modem.
        And 100.0.0.1 is not normal for the R7000P.
        doug0312 wrote:
        ...the Circle feature appears to be Dead on Arrival.
        I doubt it. My guess is the mess in those IP addresses. These services are designed to work with a conventional network, rather than some rat's nest of confusing addresses.
