abruckla
Oct 05, 2015Aspirant
Content Filtering with Netgear Genie
When I attempt to individualize the filtering settings from within the network map, the filtering setting will not change from "default level on router" regardless of the device or the alternative setting I choose. It acts like the change will take effect, but as soon as I review the details on the device it will say "default level on router."
Ultimately, I would like to have a default custom filtering level through Open DNS that is significantly high, but allow certain devices to have full access.
Please help!
- abrucklaAspirant
Genie version is 2.4.16.
The computer primarilly used to make changes has Windows 10. Many computers on the network, however, are running Linux Mint (I do not beleive Genie comes in a Linux compatible version.) I have a two other computers with Windows 10 and even 1 with Vista. The computer I use does not seem to make a difference.
Router is a WNDR3700v4. Firmware is 1.0.2.78.
- DexterJBNETGEAR Moderator
Hi abruckla,
1. Have you tried uninstalling and re-installing the app?
2. Do you mean that the issue is the same with the other Windows 10 and Windows Vista computers?
3. Please try updating the routers firmware to the latest version (1.0.2.80) and check if the issue persists.
Dexter
Community Team
