Ataraxy1's avatar
Aug 21, 2023
Deleting multiple devices
Is there a way to delete multiple devices from the network ...it has accumulated a ton of dormant devices
  • FURRYe38's avatar
    What NG product are you referring too? Model#?
    • Ataraxy1's avatar
      Ataraxy1
      Tutor
      Using the Nighthawk App ...can delete them one at. time, which is painful
  • FURRYe38's avatar
    Or factory reset the router and set up from scratch would clear everything out.
    What model router do you have?
    • Ataraxy1's avatar
      Ataraxy1
      Tutor
      Thanks. Would be more trouble to reset that delete them one at a time. Hope someone at NG sees this; the fix in the app should not be difficult.
