DmitriKaradayan
Jul 27, 2017Aspirant
DGN2200v4 as a leader for repeater
Good day!
I have the DGN2200v4 router and I'd like to connect to it my second wi-fi router - Zyxel Keenetic Start as a repeater.
But I can't force them to work together.
It seems, that DGN2200v4 cannot work in such role, but I'm not sure.
Could anybody, please, give me an answer?
Can I connect any other wi-fi router to DGN2200v4 as a repeater?
The DGN2200v4 is a modem/router, which complicates the matter.
Are you trying to create a repeater or an access point? In other words, is the connection from the DGN2200v4 to the router supposed to be wired or wireless?
- DmitriKaradayanAspirant
I'm trying to create a repeater. The connection supposes to be wireless. Wherein Netgear will be as a "Master", and Zyxel as a "Slave".
If you want the DGN2200v4 to receive wifi and pass it on to other devices, you are probably out of luck. Only some routers do that.
You can turn it into a wired access point. See page 85 of the manual.
