clkrull1
Apr 14, 2026Aspirant
Error codes and will not let me make any changes
Sorry I gave the wrong information. It’s a Nighthawk 8000 P and still after I login will not let me make any changes every time I try to do an update it says error every time I try to make any changes it says error. It won’t let me check the speed going through the router. It comes up error. It doesn’t seem like I can do anything with it, but it seems to be working. Is there any help out there? I’m ready to throw this thing in the trash.
Did you try a different browser or device?
What kind of errors are you seeing?
Does this happen on other mobile devices with the NH app loaded on it?
Can you make changes that you need to the routers web page using a web browser?
FYI, the R8000P is EoL so possible that the NH app has progressed into newer versions and may not be fully compatible anymore.
- clkrull1Aspirant
I have a Nighthawk 8100 router and it’s all I ever get after I log into the router is error codes when I’m trying to update or error codes and I’m trying to change anything. Is there anything anybody can do or do I need to replace this router? Very frustrating very frustrating.
Can you make changes with the routers web page?
Duplicate post?
