rtdeloatch
Feb 24, 2017Aspirant
Genie: 2.4.2 Device-based parental controls filtering keeps reverting back to "Default"
This problem still persists again. A previous fix was made, but I am having the same issue with Genie verison 2.4.22 for MAC, using the wireless N router. The deve-based parrental controls do not persists nor do their effects work on the specified device.
Hi rtdeloatch,
1. What is the model number and firmware version of your device?
2. Please try setting the filtering level on another device (iOS, Android, another computer).
Dexter
Community Team
- DexterJBNETGEAR Moderator
Hi rtdeloatch,
Dexter
Community Team
Hi rtdeloatch,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- rtdeloatchAspirant
Hi I was able to change the settings using the Genie App, so I no longer have the problem (though I still can't change it on my MAC computer). So the problem is sort of resolved.
