gadingan26's avatar
gadingan26
Follower
Jan 05, 2016
Genie and Windows 10
There are tons of discussions talking about this. I WAS using a really old HP pavillion running on windows vist and it worked properly, but as of right now I am using a Dell XPS with windows 10 and it does not work at all.  I've looked at all of the options that other people have tried.
I've uninstalled and reinstalled
I tried to troubleshoot the program
I tried to change the compatibility on the "properties" list
If the info is needed, I have a Netgear nighthawk AC1900 model R7000
  • michaelkenward's avatar
    michaelkenward
    I have seen suggestions about trying an older version of the Netgear Genie.
      • Archon-'s avatar
        Archon-
        Hope this helps.  Win10x64. build 10586.  Dell e7450 8GB. Latest version of genie quits immediately after splash screen appears.  Windows error log:
        Log Name: Application
        Source: Application Error
        Date: 1/7/2016 9:14:23 PM
        Event ID: 1000
        Task Category: (100)
        Level: Error
        Keywords: Classic
        User: N/A
        Computer: MyPc
        Description:
        Faulting application name: NETGEARGenie.exe, version: 2.3.1.0, time stamp: 0x55ba05d8
        Faulting module name: wpcap.dll, version: 4.1.0.2001, time stamp: 0x4c24dd97
        Exception code: 0xc0000005
        Fault offset: 0x0001b345
        Faulting process id: 0x27a8
        Faulting application start time: 0x01d149ba47a50ce5
        Faulting application path: C:\Program Files (x86)\NETGEAR Genie\bin\NETGEARGenie.exe
        Faulting module path: C:\WINDOWS\SYSTEM32\wpcap.dll
        Report Id: 385d3859-7229-4de2-9504-c778b3058828
        Faulting package full name:
        Faulting package-relative application ID:
        Event Xml:
        <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
        <System>
        <Provider Name="Application Error" />
        <EventID Qualifiers="0">1000</EventID>
        <Level>2</Level>
        <Task>100</Task>
        <Keywords>0x80000000000000</Keywords>
        <TimeCreated SystemTime="2016-01-08T02:14:23.394756300Z" />
        <EventRecordID>7035</EventRecordID>
        <Channel>Application</Channel>
        <Computer>MyPc</Computer>
        <Security />
        </System>
        <EventData>
        <Data>NETGEARGenie.exe</Data>
        <Data>2.3.1.0</Data>
        <Data>55ba05d8</Data>
        <Data>wpcap.dll</Data>
        <Data>4.1.0.2001</Data>
        <Data>4c24dd97</Data>
        <Data>c0000005</Data>
        <Data>0001b345</Data>
        <Data>27a8</Data>
        <Data>01d149ba47a50ce5</Data>
        <Data>C:\Program Files (x86)\NETGEAR Genie\bin\NETGEARGenie.exe</Data>
        <Data>C:\WINDOWS\SYSTEM32\wpcap.dll</Data>
        <Data>385d3859-7229-4de2-9504-c778b3058828</Data>
        <Data>
        </Data>
        <Data>
        </Data>
        </EventData>
        </Event>
