Birdie2971's avatar
Birdie2971
Follower
Oct 26, 2016
Genie Login
So I'm not getting money extorted from me, I'm trying to rename my 5g feed via network Genie. I can login to genie when I'm connected via 2g and have renamed this network. I use my iPad and when I try to login to change the name and password on 5g,, I get an error message : (login failed, router failed to respond with expected results.)
thanks in advance for the help.
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Birdie2971,
    1. You can also change the WiFi name and password of the 5GHz band while connected to the 2.4GHz band.
    2. You can also do the same by accessing the router's UI via a browser. You may find the link below helpful.
    http://kb.netgear.com/app/answers/detail/a_id/24095
    3. Have you tried using another device (Android app, another iOS device, Windows/MAC computer)?
    4. Have you tried uninstalling and reinstalling the app?
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Birdie2971,
    I would like to follow up and check if you are still experiencing the issue.
    Dexter
    Community Team
