blepsch
Mar 29, 2016Aspirant
Genie Parental Controls block outgoing email
I have my Parental Controls setup in my Netgear Genie application / OpenDNS. Everything works fine as far as internet browsing and incoming email. When I try to send an email, I have to disable my Parental Controls before Windows Live will send via my POP account. I'm sure this is a simple checkbox somewhere, but I've tried lots of combos of settings and can't seem to find the proper button. Please help...
- ElaineMNETGEAR Employee Retired
Do you have the Webmail selected?
Open Genie and select Change Custom Settings.
Once you're logged in, look at the Filtering level and select Customize.
