richegeland's avatar
richegeland
Genie Timeline Unspecified Error
Not sure why, but this error message keeps popping up. I can get rid of it temporarily by ending it with task manager.
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi richegeland,
    1. Are you referring to the ReadySHARE Vault program?
    2. Have you tried uninstalling and re-installing the program?
    3. Does the issue persist on your other Windows device/s?
    Dexter
    Community Team
    • richegeland's avatar
      richegeland
      Yes, it is the ReadyShare Vault Program that evidently caused the "Genie Timeline" "Unspecified Error". I uninstalled ReadyShare Vault and the error message finally disappeared.
      I have not tried to re-install yet, but will update when and if.
      Thanks for your input.
      Rich
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi richegeland,
        Thank you for the update. Please keep us posted.
        Dexter
        Community Team
  • I am having the exact same issue.  Is there a quick fix?  Please help!!
  • R7000 firmware version V1.06.28 , Os win 10
    I am also having the same unspspecified error.Blinking every second and making a strange noise. I have uninstalled and reinstalled, did a second try at backup same problem persists. Please  let me know as soon as there is a fix.
     Frank
    • jmowery007's avatar
      jmowery007
      Tutor
      Having the same issues.  Uninstalled/installed Genie and Readyshare.  Still keeps happening, can't get a backup done.  Can't find any solution out here.  Someone said to install old versions but I can't locate those on the support download page.  Any ideas?
