carll76
Oct 05, 2015Apprentice
Genie Updated last night.. Now will not work (windows 10)
Hello, Genie updated last night and will not working on my windows 10 surface pro. I've unstalled and reinstalled a number of times as both admininstrator and normal user. Any ideas on fixing t...
carll76
unfortunalty I didn't set a restore point.. Didn't think I would need it as only updated an app...
carll76
Just installed the app on another windows 10 laptop (one that I have never installed the app on before) same issue.. Same error...
- michaelkenwardOct 05, 2015Guru - Experienced User
It installed fine here on two PCs.
No System Restore? Investigate making it happen.
This should not be something that you need to create. Windows should do it automatically unless you tell it otherwise. Maybe Windows 10 thinks you don't need it. Grrr.
- carll76Oct 05, 2015Apprentice
Windows 10 does it but you have to tell it :)
I'm thinking it could be router side.. Preventing it from connecting ??
Might factory reset the router in tommrow and see if it works.
