WordWoman's avatar
WordWoman
Great connection, weak signal on Amazon Fire Tablet
Genie Wi-Fi analytics says the Fire tablet is connected at -28 dBm but just 4% signal strength. This seems to happen often. What is wrong?   The Nighthawk 1750 sits next to a Brother wireless print...
  • DexterJB's avatar
    Nov 08, 2017
    Hi WordWoman,
    1. You may be too close to the router when doing the test
    2. Please try testing while you are at least 5 feet from the router.
    3. Do they (WiFi analytics and Genie) still have different results at a further distance?
    4. On which band are the devices connected?
    5. Does the issue persist on both bands?
    6. Have you tried using a wireless computer (non-mobile device)?
    Dexter
    Community Team
