  • plemans's avatar
    That's their negotiated link rate between router-----device. It can change based on distance/interference.
    And it gives you a rough idea of how fast the connection is because usually actual throughput speed is roughly 55-65% of link speed.
    • Slr8929's avatar
      Slr8929
      I have a device on the app that says the link rate is 144Mbps does that mean that is the amount of speed it’s using?
      • plemans's avatar
        Thats its connection to the router, not the amount of bandwidth used.
