pko's avatar
pko
Novice
Sep 21, 2013
iOS 7 breaks Genie Airprint
Using latest Genie (2.2.28.24) and WNDR4500 firmware (V1.0.1.36_1.0.6.3), I was able to print easily from my iPhone5 with iOS 6. After upgrading to iOS 7, Genie's Airprint feature no longer works with the iPhone5. Still works fine with my older iPad with iOS 5. Please, Netgear: Update Genie to be compatible with iOS 7!
Does anybody from Netgear read these posts? I tried to explain the problem to Netgear support, and asked them to request an update, but they didn't really understand what I was talking about.
  • Downloaded new windows update on computer and AirPrint does indeed work, as long as you computer is on!
  • In my case, selecting print from my ipad or iphone:
    1) wakes the printer.
    2) opens Adobe.
    3) then never prints.
    I could print from adobe but it seems like a lot more hoops and hurdles than necessary.:(
  • Hello,
    I'm running Windows 8. I've had an N900 router for awhile but just now hooked up the printer to use ReadyShare print on a (non-AirPrint compatible) Dell 2155cdn color laser printer. All of my iOS devices have been upgraded to iOS7 before trying to use ReadyShare.
    I have the NETGEAR USB control center/media extender version 1.32 (driver version 1.74.27) installed on my Windows 8 machine (that has the N900 plugged into it).
    I have NETGEAR Genie version 2.3.1.16 installed (though I don't think that being installed is necessary for ReadyShare print).
    My issue/question: I've never used ReadyShare Print before. When I went to try to print, it shows NO printers are installed. Is that the result that is expected with this issue - or do I have another problem?
    Thanks for your help! I did submit a trouble ticket to Netgear saying I can't get it to print on iOS7.
    Thanks
