Meebs's avatar
Meebs
Follower
Aug 22, 2017
Limit time per device R7000
Is there a way to set specific time restrictions on individual devices? For example, cut off access to an iPad at 9pm until 6am, cut off access to a laptop at 10pm until 6am, etc.
It looks like I can cut off wifi access entirely for certain periods of time in the Security section and I can also "pause" internet for specific devices manually through the genie app.
But if there is a way to set up scheduled time restrictions BY DEVICE, I can't find it.
Thank you!
  • I have not used it  but it looks like the genie app and parental controls can do something like it..  you can put devices indivually in a different schedule type anyway ..
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Meebs,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
