niallg
May 01, 2022Aspirant
MR60 / MS60 Firmware Version 1.1.6.124 Access Control No Longer working
My router updated to V1.1.6.124 yesterday and now access control from the iphone app no longer works. There is a new slider when you select the device, but the slider is grayed out and you cannot change it. This setting can still be updated using the web interface. Anyone else have this problem?
Got a screen capture of this?
Is Armor enabled?
Has a factory reset and setup from scratch been performed since update?
Be sure to disable WiFi Private Address and Limit IP Address Tracking on Apple devices.
