jnb9265
May 25, 2022Aspirant
Neghthawk App
Unable to access my router by using the Nighthawk app. I get a logon timed out, please tryagain if this issues persists, try rebooting your device
I have rebooted both my mobile device and router several times still geting error message.
I can sign on to router by going to routerlogon.com and using my admin credentials
only when using the app ....I have removed app from phone and reinstall. Using Android. I had been able to access through the app until yesterday
I downloaded night hawk app on my iPad i did get the error message but got a option to access anywhere...i selected that and its saying my device is offline but i am connected to the router.
Which router? What is the firmware on it?
What modem/gateway sits in front of it?
- jnb9265Aspirant
Router is a r6400v2 attached to an Arris CM820A cable modem
Firmware is v1.0.4.122_10.0.95
Standard modem. No router to get in the way.
Firmware is v1.0.4.122_10.0.95Not the latest, although it should still work. But worth getting the newest:
R6400v2 Firmware Version 1.0.4.126 | Answer | NETGEAR Support
- frankburke007Aspirant
Hey,
Which router you are using right now??? Kindly tell me about the router specifications and model.
Thanks
- jnb9265AspirantUsing a r6400v2 router with Firmware being v1.0.4.122_10.0.95.
I am using both a iPad and a Google pixel 3 which have both been used to connect to router their appropriate apps...uninstalled and reinstalled apps. I know the password and userid are coorect as I can sign in there the router login.com url
