Lsbcal
Oct 07, 2014Aspirant
Netgear Genie app does not open
I've been using this off and on for a few years. Just tried to bring up the Netgear Genie app and it did not respond. The wireless router is working fine. I have a Win 7 desktop PC as the main computer, all up to date.
Can I uninstall and reinstall the Network Genie without disturbing the settings on the WNDR4500 (N900) router? Is it that simple a fix?
- covillen1ApprenticeHey Lsbcal,
you should be able to. The genie is just an app that has access to the router. It doesn't hold your router settings. I think you're good with uninstalling the genie and re installing it - LsbcalAspirantThanks for the reply Covillen. If there are no further comments to this in a couple of days (no hurry on this I guess) then I'll to the reinstall.
- LsbcalAspirantToday I uninstalled Netgear Genie and reinstalled it. Works fine now.
- covillen1ApprenticeLsbcal
Great Cool! I'm glad everything worked out!!!! :D- Spanky48Aspirant
I am having a similar issue with my R6250. Whenn I try and open it I get a "Netgear Genie has stopped working" it goes out in windows and looks for a solution. Comes back with a no solution availablle. I have uninstalled and re-installed twice with no success......HELP
- DexterJBNETGEAR Moderator
Hi Spanky48,
Are you encountering the issue on a Windows 10 device? If so, you may use the download link below for the previous version (2.4.12) of the NETGEAR Genie program.
http://files.netgear-support.com/go/?a=d&i=gRJKu6dWnB
Dexter
Community Team
