niko158
Feb 10, 2018Aspirant
Netgear Genie crashes
Hello, I'm having a problem with the Netgear Genie app on my Iphone. It keeps crashing and it won't open. I have an Iphone 7. A lot of users have problems with it and it's getting a really bad ...
schumaku
Feb 10, 2018Guru - Experienced User
wrote:I'm having a problem with the Netgear Genie app on my Iphone. It keeps crashing and it won't open. I have an Iphone 7. A lot of users have problems with it and it's getting a really bad rating on the App Store. It seems that the last time it worked was december or something.
And just a single problem report in the community since? Strange to me. Afraid, can't test, no iOS system at hand these minutes.
wrote:
The Pc version won't work on my Surface Book with win10 either. I tried to run it with compability mode but it doesn't work and I'm not finding any other old versions to download to test it.
Have downloaded the current Netgear Genie from the Netgear Genie page - DOWNLOAD PC link. Installed flawless on a current and up2date Windows 10 64 bit system - perfectly workable App (not using ie. printing however). Version shown is v2.4.52 - as per the Genie Desktop Version 2.4.52 / 2.4.32, Updated Jan 25, 2018
As you can't see a version number (and the NETGEARGenie.exe version number is not updated in the code, it is still 2.4.44.0 from July 2017) - check the installed binaries DLL dates:
Hope this does help to identify the version installed on your WIndows 10 system.
niko158
Feb 18, 2018Aspirant
Well, if the rating is 1,2 stars maybe you should consider taking a look at it. My Iphone can't be the problem.
I checked the dates of dll files. Everything looks exactly the same. When I start it, it shows the logo at the beginning and a warning shows up "Netgear Genie funktioniert nicht mehr". The same happens in IOS (without the warning ofc).
If you could send me an outdated version at least, I'd be glad.
- schumakuFeb 20, 2018Guru - Experienced User
niko158wrote:Well, if the rating is 1,2 stars maybe you should consider taking a look at it. My Iphone can't be the problem.
I'm not Netgear. Browsing over Google Play as well as the English iTunes store does not show such a poor rating.
- niko158Feb 20, 2018Aspirant
Sorry, I didn't realize that.
In Android it's working fine. I tested the app at two different Iphones 7 today and it crashed at each of them.
Demonstration: https://drive.google.com/open?id=1yBB4fwF7G2iZ90aX7lmT2cDYbuU7afX2
The only reason I need it to be working on my Iphone is for using the Bypass Account because as far as I know you can't do it any other way.
