wgblondel's avatar
wgblondel
Netgear Genie NSIS Error
Hi.
I try to install Netgear Genie on a Windows 10 64bit machine but the installer won't run.
I downloaded it multiple times from Netgear's website on multiple computer but I have the same error every time.
"NSIS Error
Installer integrity check has failed. Common causes include incomplete download and damaged media. Contact the installer's author to obtain a new copy."
Please fix that.
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi jpoinpoin,
      Have you tried downloading the installer using another device/computer?
      Dexter
      Community Team
      • jpoinpoin's avatar
        jpoinpoin
        Bonjour Dexter,
        Yes I have tried downloading the installer using another computer and it works.:manvery-happy:
        But this does not resolve the problem I get on my usual PC (same level of Windows 10 64bits).:manfrustrated:
        Jacques
