jjdonahue
Oct 21, 2015Aspirant
NETGEAR Genie Parental Control by Device has no effect
In NETGEAR Genie Network Map I see all the attached devices
I rightclick my son's and daughter's devices - set Parental Contols Filtering to HIGH
However i see no effect. Obvious adult sites are not filtered
I've rebooted the router and the devices
I'm not using the bypass account. I hope the answer isnt to install the bypass app on every device that uses my network
Devices Ive tested to no avail:
Nook
iPhone 5s
iPad mini
- jjdonahueAspirant
router is r7000
- jjdonahueAspirant
Thank for the reply
Yes - still no filtering is apparent on any of 5 devices I'm testing (iPhone 4 and HP Windows 10 laptop added to my test list)
Because its all devices on my network, Im convinced its a central set-up issue
On my router - the primary DNS and Secondary DNS are the IP addresses you list above
