Praezin's avatar
Praezin
Netgear Genie Windows won't run
I have downloaded and installed and tried to run Genie on my Windows 10 machine, but alas nothing happens. I get runtime error and it closes the program. Newer Windows 10 machine, completely uptodate. Here is my event viewer log for the error:
Faulting application name: NETGEARGenie.exe, version: 2.4.1.0, time stamp: 0x00030000
Faulting module name: GeniePlugin_Map.dll, version: 0.0.0.0, time stamp: 0x06034518
Exception code: 0xc0000005
Fault offset: 0x00286621
Faulting process id: 0x282c
Faulting application start time: 0x01d25270ca350ae9
Faulting application path: C:\Program Files (x86)\NETGEAR Genie\bin\NETGEARGenie.exe
Faulting module path: C:\Program Files (x86)\NETGEAR Genie\bin\GeniePlugin_Map.dll
Report Id: 2607016a-83c4-4329-a712-f94e6ef26b92
Faulting package full name:
Faulting package-relative application ID:
    • Praezin's avatar
      Praezin
      Thank you for the suggestion. I have my standard login ID which is set as a standard user (for security). I tried to run Genie with the 'Run as Administrator' option on right-click...low and behold it works! Still aggravating that I have to do that.
      EDIT: I downloaded the latest version straight from netgear site and yet, when I get to the router settings page, there is no drop down for remote like in the video.
      • Hmm. Gets even more confusing.
        Your message prompted me to upgrade to the newer Windows genie.
        That seems to work. Today at least.
