redonaldson's avatar
redonaldson
Netgear Nighthawk RAX120
I have three Nighthawk routers at different locations. Recently my ability to remotely access and perform management and rebooting stopped. Can anyone help with what I might do to regain that feature?
  • FURRYe38's avatar
    What 3 routers do you have?
    Is this thru the Nighthawk app?
    • redonaldson's avatar
      redonaldson
      All three are RAX 120 Routers on 400 MBPS connections. All three worked great with Remote until a few weeks ago and something changed and cut Remote off on all three routers. I can access the router via the app when I am on that network. One is 35 mile from home and one is 15 miles from home - quite inconvenient when issues arise.
      • FURRYe38's avatar
        What version of the app are you using?
        Is there a screen capture of what you see that you can post here?
        Do you know if these 120s are v1s or v2s?
