AMCL
Sep 28, 2017Guide
NETGEAR USB Control Center macOS High Sierra
Hi everybody, After updating to macOS High Sierra, USB Control Center stopped working. It complains about “installation could not be completed” and suggest a reinstallation, but neither a reinstal...
- Jan 13, 2018
Finally a public release !!
emjaay
Sep 28, 2017Guide
Having the same issue on MacOS High Sierra . Tried uninstalling and installing again but in vain . Following error if i try manually from console ,
/Applications/NETGEAR/NETGEAR\ USB\ Control\ Center.app/Contents/MacOS/NETGEAR\ USB\ Control\ Center ; exit; [Info] Software Version: 1.02.71 2017-09-29 11:10:06.830 NETGEAR USB Control Center[68096:1199139] Mac Version: 10.13.0 2017-09-29 11:10:06.830 NETGEAR USB Control Center[68096:1199139] main 2017-09-29 11:10:06.831 NETGEAR USB Control Center[68096:1199139] GetIPAddressesByOTA 2017-09-29 11:10:06.831 NETGEAR USB Control Center[68096:1199139] MacIPAddress=127.0.0.1 2017-09-29 11:10:06.831 NETGEAR USB Control Center[68096:1199139] MacIPAddress=10.67.120.34 [NetUSB] IOServiceGetMatchingServices err: 0 [NetUSB] IOServiceOpen err: 268435459 NetUSBInit() failed! 2017-09-29 11:10:06.837 NETGEAR USB Control Center[68096:1199139] ThisLanguage: en-IN /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.1.1/Common/ChunkCompression.cpp:50: Error: unsupported compressor 8 /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.1.1/Libraries/CompressData/CompressData.c:353: Error: Unknown compression scheme encountered for file '/System/Library/CoreServices/CoreTypes.bundle/Contents/Resources/Exceptions.plist' /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.1.1/Common/ChunkCompression.cpp:50: Error: unsupported compressor 8 /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.1.1/Libraries/CompressData/CompressData.c:353: Error: Unknown compression scheme encountered for file '/System/Library/CoreServices/CoreTypes.bundle/Contents/Library/AppExceptions.bundle/Exceptions.plist' [Info] Mac Version: 10.13.0 2017-09-29 11:10:06.926 NETGEAR USB Control Center[68096:1199139] [Info] Mac Version: 10.13.0 PlayToPC = 0, PlayToWAA = 1 WAAThreadStart Start
Please give a fix soon..
- DexterJBNov 02, 2017NETGEAR Moderator
Hi all,
Let me check on this.
Dexter
Community Team
- onewarmlineNov 09, 2017Tutor
Same -- the already-terrible Netgear USB control app is now completely non-functional following upgrade to OS10 High Sierra.
It would be really nice if Netgear would take the time to make the router's USB functionality accessible for Mac users, in a way that doesn't involve a shockingly buggy app that looks like something from the 1990s. C'mon.
Anyway, what did you find out from Netgear?
thx
- papa43Nov 09, 2017Tutor
- westanneyNov 12, 2017Aspirant
Anyword yet? I am having this issue on two MacBook Pros....
Thanks
- emanonNov 24, 2017Tutor
DexterJB wrote:Hi all,
Dexter
Community Team
Any word on a resolution?
- ddreggorsNov 27, 2017Aspirant
Same issue here, upgraded to High Sierra and now the NETGEAR USB Control Center fails to open with message "Installation incomplete".
Can we get an update or some word on an upcoming update please?
