AMCL
Sep 28, 2017Guide
NETGEAR USB Control Center macOS High Sierra
Hi everybody, After updating to macOS High Sierra, USB Control Center stopped working. It complains about “installation could not be completed” and suggest a reinstallation, but neither a reinstal...
- Jan 13, 2018
Finally a public release !!
Bwhast
Oct 02, 2017Initiate
Maybe the Netgear USB Control Center is not needed in High Sierra!!
Since posting here a couple of days ago to say that I, too, was unable to use the USB Control Center in High Sierra, I deleted it (using the uninstall program included with it) and rebooted. Then, just for the hey of it, I checked to see if I could connect my printer without it. Son of a gun, my printer was now listed as a Bonjour option for installation! I installed it, and it is working fine!
AMCL
Oct 02, 2017Guide
Nice finding, definitely it is possible to print using Bonjour but... you stil need USB control center to use, i.e, the scanning function of a MFP.
I wonder when somebody from Netgear will give us a solution, or at least an explanation...
