AMCL
Sep 28, 2017Guide
NETGEAR USB Control Center macOS High Sierra
Hi everybody, After updating to macOS High Sierra, USB Control Center stopped working. It complains about “installation could not be completed” and suggest a reinstallation, but neither a reinstal...
- Jan 13, 2018
Finally a public release !!
RRM855
Oct 23, 2017Apprentice
Yes, One always expects glitches on major OS updates. But these are typically rapidly resolved. For every other peripheral device I own, they are ahead of the game and anticipating the release. There is always new software for my devices for the Mac OS update. Not true with Netgear. I do not anticipate this being addressed any time soon if at all. Makes no sense that one of the big 3 router companies does not have the ability to do this. Now I have my printer plugged into my USB port of my MacBook Pro. I will dump Netgear equipment and change to another brand router. It is not worth the hassle for what are essentially cheap pieces of hardware.
Gentilly
Oct 30, 2017Tutor
Now, Netgear USB Control Center is not needed in High Sierra!!
I was unable to use the USB Control Center in High Sierra. I uninstall it and rebooted. I checked to see if I could connect my printer without it. My printer was now listed as a "Bonjour" option for installation! I installed it, and it is working fine!
RRM855 wrote:Yes, One always expects glitches on major OS updates. But these are typically rapidly resolved. For every other peripheral device I own, they are ahead of the game and anticipating the release. There is always new software for my devices for the Mac OS update. Not true with Netgear. I do not anticipate this being addressed any time soon if at all. Makes no sense that one of the big 3 router companies does not have the ability to do this. Now I have my printer plugged into my USB port of my MacBook Pro. I will dump Netgear equipment and change to another brand router. It is not worth the hassle for what are essentially cheap pieces of hardware.
- RRM855Oct 31, 2017Apprentice
Where is it listed as a Bonjour option for installation without the utility? I did not understand your sequence of steps.
- emjaayOct 31, 2017Guide
AFAIK there is no special menu for bonjour . When you go to ' System Preferences' >> ' Printers and Scanners ' - You printer will be listed by detecting over the network
However i couldnt access scanner that way..
- GentillyNov 01, 2017Tutor
emjaay wrote:AFAIK there is no special menu for bonjour . When you go to ' System Preferences' >> ' Printers and Scanners ' - You printer will be listed by detecting over the network
Right. I don't see my Epson Scanner on the listing of Printers & Scanners. I don't know why.
