AMCL
Sep 28, 2017Guide
NETGEAR USB Control Center macOS High Sierra
Hi everybody, After updating to macOS High Sierra, USB Control Center stopped working. It complains about “installation could not be completed” and suggest a reinstallation, but neither a reinstal...
- Jan 13, 2018
Finally a public release !!
emjaay
Sep 28, 2017Guide
Having the same issue on MacOS High Sierra . Tried uninstalling and installing again but in vain . Following error if i try manually from console ,
/Applications/NETGEAR/NETGEAR\ USB\ Control\ Center.app/Contents/MacOS/NETGEAR\ USB\ Control\ Center ; exit; [Info] Software Version: 1.02.71 2017-09-29 11:10:06.830 NETGEAR USB Control Center[68096:1199139] Mac Version: 10.13.0 2017-09-29 11:10:06.830 NETGEAR USB Control Center[68096:1199139] main 2017-09-29 11:10:06.831 NETGEAR USB Control Center[68096:1199139] GetIPAddressesByOTA 2017-09-29 11:10:06.831 NETGEAR USB Control Center[68096:1199139] MacIPAddress=127.0.0.1 2017-09-29 11:10:06.831 NETGEAR USB Control Center[68096:1199139] MacIPAddress=10.67.120.34 [NetUSB] IOServiceGetMatchingServices err: 0 [NetUSB] IOServiceOpen err: 268435459 NetUSBInit() failed! 2017-09-29 11:10:06.837 NETGEAR USB Control Center[68096:1199139] ThisLanguage: en-IN /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.1.1/Common/ChunkCompression.cpp:50: Error: unsupported compressor 8 /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.1.1/Libraries/CompressData/CompressData.c:353: Error: Unknown compression scheme encountered for file '/System/Library/CoreServices/CoreTypes.bundle/Contents/Resources/Exceptions.plist' /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.1.1/Common/ChunkCompression.cpp:50: Error: unsupported compressor 8 /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.1.1/Libraries/CompressData/CompressData.c:353: Error: Unknown compression scheme encountered for file '/System/Library/CoreServices/CoreTypes.bundle/Contents/Library/AppExceptions.bundle/Exceptions.plist' [Info] Mac Version: 10.13.0 2017-09-29 11:10:06.926 NETGEAR USB Control Center[68096:1199139] [Info] Mac Version: 10.13.0 PlayToPC = 0, PlayToWAA = 1 WAAThreadStart Start
Please give a fix soon..
DexterJB
Nov 02, 2017NETGEAR Moderator
Hi all,
Let me check on this.
Dexter
Community Team
