AMCL
Sep 28, 2017Guide
NETGEAR USB Control Center macOS High Sierra
Hi everybody, After updating to macOS High Sierra, USB Control Center stopped working. It complains about “installation could not be completed” and suggest a reinstallation, but neither a reinstal...
- Jan 13, 2018
Finally a public release !!
RRM855
Nov 12, 2017Apprentice
Right now I am using the USB connection from the router without the USB Network Control Center installed. It is slow but appears to work with my color laser printer. One advantage is I do not have to keep reconnecting the printer like I did with Netgear's software. It used to time out repeatedly leaving the printer off line.
onewarmline
Nov 13, 2017Tutor
I've tried to do this, but I haven't been able to make it work. Would you mind sharing the procedure you followed? thx!
- RRM855Nov 13, 2017Apprentice
I just plug the USB in and go to Systems Preferences then Printers and Scanners. I add printer (+) and my printer shows up with a new name, a series of numbers and characters. I suppose that is some sort of IP address? The original printer name also appears in the list. I just switch this new printer as the default printer.
