AlexWaltz
Jan 29, 2017Aspirant
NetGenie doesn't work with my router
I've setup my Nighthawk R7000 router and used the NetGenie app to enable parental controls. Once this was done, I sent the OpenDNS default filtering level to high. I then used the Network Map in NetGenie to reduce the filtering level to moderate on my laptop.
What I'm finding is that the lower filtering level on my laptop does not work. While the filtering level might be set to moderate, there is actually no filtering taking place. I know this because I tested out some sites that should have been blocked but they were not.
I had OpenDNS reset my account and I have also reset my router to factory defaults, but the issue remains. My Nighthawk R7000 router is using the newest firmware available when I check for updates and that firmware version is V1.0.7.6_1.1.99.
Thank you
Hi AlexWaltz,
1. Please make sure that the DNS values on the router UI are set to 208.67.222.222 and 208.67.220.220.
2. Are all devices affected?
3. Please make sure that the settings are in sync when you login to https://netgear.opendns.com/sign_in.php.
Dexter
Community Team
- AdewaleLuminary
shouldn't this post be titled "Parental control doesn't work with my Router"?
