Anh28EZ
Dec 03, 2020Aspirant
Nighthaw App stopped working
Hello, I just noticed that when I enable Circle on the web, I can't login to my Nighthawk App on my phone. I tried to reset the app but it just shows login timeout. It only work again if I disable C...
michaelkenward
Dec 04, 2020Guru - Experienced User
Have you tried this issue in the section given over to Circle?
Circle Smart Parental Controls - NETGEAR Communities
- Anh28EZDec 12, 2020Aspirant
I'm not sure if this related to Circle or not. I can't find any post related to this.
- michaelkenwardDec 13, 2020Guru - Experienced User
Why did you mention it twice in your first message then?
You do something to Circle. Your router does strange things.
Seems likely to be connected to me.
- Anh28EZDec 14, 2020Aspirant
If I use Circle Parental Control, then I can't no longer login to the Nighthawk app. I contacted to Netgear about this but they haven't found a solution for this.
