yatman60's avatar
Jun 14, 2023
Nighthawk Android App
The android version of the Nighthawk app isn't connecting to the CAX80 Router. Whenever you try and login it says the router is unreachable despite it actually finding the router on first launch where it shows "We've Connected to your Nighthawk.
When you go past that screen to the Dashboard, it asks you to login and it says the router is unreachable.
I tried the iOS app and it works fine and I even used the web browser with success.
