dipb
May 05, 2021Aspirant
Nighthawk App (Android) - not able to connect to Router after 04/05 update
HI, I have Netgear R7800. The router is working fine and I was able to login to the router remotely from my mobile using the Nighthawk app. However, on 04/05/2021, Netgear released a new version of t...
dipb
May 11, 2021Aspirant
Hi Christian, the Nighthawk R7800 is having firmware version 1.0.2.82. Checked now that this is the latest available.
Any resolution suggested?
Christian_R
May 14, 2021NETGEAR Employee Retired
Hi dipb,
May you factory reset your router by holding down on the reset button for 15+ seconds and running through the setup assistant again using the Nighthawk app.
Christian
- dipbMay 15, 2021Aspirant
HI Christian, I would disagree it is a router problem. The Router still works perfectly and why would one reset to factory settings.
The problem is with the app and the same is also evident from other users leavingsuch feedback in Play Store.
No matter you give right pasdsword or wrong password, it smiply says connection to router timed out. This issue cropped up after the latest version of the app was released. You can see the feedback on GooGle Play Store.
It is worth development team focus on the fix.
- michaelkenwardMay 16, 2021Guru - Experienced User
That is a standard troubleshooting tactic. Certainly more magic than reasoned thinking, but if you aren't prepared to try it, then you probably have to live with things. After all, a reset doesn't have to be permanent.
It might if everyone saw the same behaviour. I don't recall seeing a flood of complaints after the update.
The new version works perfectly here on my R7800.
How are you connecting? Local connection or Anywhere Access?
Both are trouble free at my end.
