Joekidd's avatar
Joekidd
Nighthawk app does not log into my Netgear Nighthawk R7000 router
The issue started when I upgraded my phone to an Iphone 13 Max Pro, latest IOS. My Netgear Nighthawk R7000 firmware is current and up to date. My Nighthawk app is the latest release. I am able to login to my router using 192.168.1.1 and everything is working fine. I recently subscribed to Netgear Armor and the only way to enable the security feature on the router is through the app. Previously, when trying to install the app I would get login timed out, or router is off line. I then did a factory reset on the router and did a fresh install. It would go through the process, find the router, say cables are connected, but time out and say no internet connection. Where I then did the advanced install and provided, the ip address, subnet mask, DNS, etc. etc.. Same results. And before you suggest it I checked that the app was set to local network and turned off the Phones VPN setting. Same result. Finally I just logged back onto the router over the web and set the router back up. Everything is working as before, the router just says that Armor is not enabled! Firmware really needs to allow folks to toggle this on and just forget/ignore the app.
