LSJR3
Apr 01, 2026Follower
Nighthawk app jumble up
Hello. Does anyone have an error in the Nighthawk app that makes the login area impossible to select anything but "forgot password"? I tried to attach a screenshot that I had taken but every time I hit "publish" an error message that said something along the lines of cannot publish now, uploading in progress. Try again later.
The Community Forum software has lost the ability to paste an image into a conversation (a little over 12 weeks ago). it is frustrating and extremely annoying.
Can you install the Nighthawk app on a different smartphone or tablet?
LSJR3 wrote:
... the Nighthawk app that makes the login area impossible to select anything but "forgot password"?
Uninstalling and re-installing the Nighthawk App does not change anything?
On Android, start with a [Clear Cache} close and re-open the App. If this alone does not cure, try [Clear storage] and re-open. I guess you have to re-authenticate on the Netgear cloud.
