Shane-Woodend's avatar
Oct 04, 2020
Nighthawk App not retaining Saved device names
I have an R6020 AC750 WiFi Router and I run the Nighthawk App on my Nokia phone (Android 10). There are 2-3 devices that always show up in the Device Manager as "Unknown". I have identified what these devices are and EDITED and SAVED their Names in the App, but the edits are not being retained, if I close the App and reopen it, those devices are back to "Unknown". As far as I know the App is the latest version - V2.6.4.1264  Anybody know anything about this issues ?
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi Shane-Woodend,
    May you reinstall the Nighthawk app and power cycle your router.
    Christian
    • Shane-Woodend's avatar
      Shane-Woodend
      Thanks for your suggestion, just finished going through that process, unfortunately it did not make any difference at all.
        Christian_R
        Hi Shane-Woodend,
        Thanks for confirming. May you access the router's admin page by visiting http://www.routerlogin.net/ using a web browser. Please let me know if you're able to edit the attached devices list using the admin page.
        Christian
