noraiko's avatar
noraiko
Tutor
Nov 22, 2019
Nighthawk App Router Setup Loop
Hello! I have my Nighthawk X4 AC2350 upstairs, which is connected to an ATT BGW210 router downstairs in attempts to boost the signal upstairs. The Nighthawk router wifi currently has the same name/password as the ATT router downstairs. I've had trouble configuring the nighthawk via routerlogin.net (routerlogin won't produce a login screen, instead telling me that "You may not be connected to your Router’s WiFi network."), so I downloaded the Nighthawk mobile app on the Google Play Store. I have a Samsung S9 and running Nighthawk ver 2.4.12.876.
I've been able to set-up the router on the mobile app, but during the last step of the process, I get an error message saying "Something went wrong. Please try again", which then won't go away until I close the app. Upon reopening the app, it says that the router has not been set up, and wants to start the process over again.
This problem also happens after choosing a different name for the wifi.
  • plemans's avatar
    The problem is that you're running both routers in router mode. Its causing a double nat.
    https://kb.netgear.com/30186/What-is-Double-NAT
    You either need to place the att device in modem only mode or you need to switch the netgear router to AP mode. this will fix a lot of your conflicts.
    to access/managed the netgear router, unhook it from the att device. then try to go through the setup. This will let you manage and switch it to AP mode. Once switched, hook it backup to the Att device.
    • michaelkenward's avatar
      michaelkenward
      Spot on there, but here is the bad news:
      Solved: How can I put BGW210 gateway on bridge mode? - AT&T Community
      from
      at&t bgw210 bridge mode - Google Search
    • noraiko's avatar
      noraiko
      Tutor
      plemans thank you for your response!
      I attempted to set the router into AP mode, but I'm not sure if I've successfully done so. I reset the Nighthawk router, and was able to access routerlogin.com. However, after setting the router to "AP mode" there was a failure message. I didn't clearly see what it was, and I haven't been able to get the router to let me back onto routerlogin.com to try again (even after trying to reset it again). When I tried setting it to AP mode, I had the router plugged into the wall plug that's been giving the ATT router a connection.
      Now when I plug the Nighthawk to the ATT router, the internet light is orange. Is this normal for a router in AP mode? Attached is a picture of the router and its illuminated lights. I'm in the same room as the router, and I've only got 3/4 bars as opposed to all four of the bars being on while I had the double NAT going.
      Thank you so much again for your response and time!
