Mandy21185
Dec 21, 2022Aspirant
NightHawk app saying MR60 not supported
I just hooked up my new mesh MR60 router with one satellite. When i go to my nighthawk app it shows a pic of the router and says connecting, then goes to a screen that says MR60 The app does not support your router model.... even though every QR code or link on the routerlogin.com brings me to the same app... i tried uninstalling and reinstalling. No luck... Help!
There a screen capture of this?
NH app is supporting of the MK system.
What mobile platform are you using? Apple or Android?
- Mandy21185Aspirant
Have you tried simply installing it manually through the browser? Thats my preferred method of install
